The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun igroup initiator modify
PDF of this doc site
Creating your file...
Your file is ready
Modify an initiator
This command modifies an attribute for an initiator.
-vserver <Vserver Name>
- Vserver-
Specifies the vserver of the initiator you want to modify.
-initiator <text>
- Initiator-
Specifies the initiator whose attribute you want to modify.
[-comment <text>]
- Comment-
The initiator's new comment. The comment has a maximum length of 255 characters. To clear the current comment, provide an empty string.
cluster1::> lun igroup initiator modify -vserver vs1 -initiator iqn.1991-05.com.example:name -comment "My application host"
Changes the comment to "My application host" for initiator iqn.1991-05.com.example:name
in Vserver vs1
cluster1::> lun igroup initiator modify -vserver vs1 -initiator iqn.1991-05.com.example:name -comment ""
Clears the comment for initiator iqn.1991-05.com.example:name
in Vserver vs1
