      lun igroup initiator modify
Modify an initiator
This command modifies an attribute for an initiator.
- -vserver <Vserver Name>- Vserver
Specifies the vserver of the initiator you want to modify.
- -initiator <text>- Initiator
Specifies the initiator whose attribute you want to modify.
- [-comment <text>]- Comment
The initiator's new comment. The comment has a maximum length of 255 characters. To clear the current comment, provide an empty string.
cluster1::> lun igroup initiator modify -vserver vs1 -initiator iqn.1991-05.com.example:name -comment "My application host"
Changes the comment to "My application host" for initiator iqn.1991-05.com.example:name in Vserver vs1 .
cluster1::> lun igroup initiator modify -vserver vs1 -initiator iqn.1991-05.com.example:name -comment ""
Clears the comment for initiator iqn.1991-05.com.example:name in Vserver vs1 .
 PDFs
PDFs
