lun igroup initiator modify
Modify an initiator
This command modifies an attribute for an initiator.
-vserver <Vserver Name>- Vserver-
Specifies the vserver of the initiator you want to modify.
-initiator <text>- Initiator-
Specifies the initiator whose attribute you want to modify.
[-comment <text>]- Comment-
The initiator's new comment. The comment has a maximum length of 255 characters. To clear the current comment, provide an empty string.
cluster1::> lun igroup initiator modify -vserver vs1 -initiator iqn.1991-05.com.example:name -comment "My application host"
Changes the comment to "My application host" for initiator iqn.1991-05.com.example:name in Vserver vs1 .
cluster1::> lun igroup initiator modify -vserver vs1 -initiator iqn.1991-05.com.example:name -comment ""
Clears the comment for initiator iqn.1991-05.com.example:name in Vserver vs1 .
