ONTAP commands
vserver cifs symlink modify
Modify a symlink path mapping
The vserver cifs symlink modify command modifies the CIFS share name, CIFS path, CIFS server name, or locality of a symbolic link mapping. It can also be used to modify the value of -home-directory field.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver on which the symbolic link mapping is located.
-unix-path <text> - UNIX Path
This parameter specifies the UNIX (NFS) path of the mapping that you want to modify.
Note It must begin and end with a forward slash (/).
[-share-name <Share>] - CIFS Share
This parameter specifies a new CIFS share name for the mapping.
[-cifs-path <TextNoCase>] - CIFS Path
This parameter specifies a new CIFS path for the mapping. Note that this value is specified by using a UNIX-style path.
[-cifs-server <TextNoCase>] - Remote NetBIOS Server Name
This parameter specifies a new CIFS server DNS name, IP address, or NetBIOS name for the mapping.
[-locality {local|widelink}] - Local or Wide Symlink
This parameter specifies a new locality for the mapping. A local symbolic link maps to the local CIFS share. A free symbolic link can map anywhere on the local server. A wide symbolic link maps to any CIFS share on the network. The default setting is local . The free link option is obsolete.
[-home-directory {true|false}] - Home Directory
This parameter specifies whether the new target share is a home directory.
Note This field must be set to true when the target share is a Home Directory for correct processing.
The following example modifies the symbolic link mapping to a UNIX path /example/ on a Vserver named vs1. The mapping is modified to use the CIFS path /mycompany/example/.
cluster1::> vserver cifs symlink modify -vserver vs1 -unix-path /example/ -cifs-path "/mycompany/example/"
The following example modifies the symbolic link mapping to a UNIX path /example/ on a Vserver named vs1. The mapping is modified to use the CIFS share name EXAMPLE_SHARE, the CIFS path /mycompany/example/, on the CIFS server cifs.example.com, and to be a wide link.
cluster1::> vserver cifs symlink modify -vserver vs1 -unix-path /example/ -share-name EXAMPLE_SHARE -cifs-path "/mycompany/example/" -cifs-server cifs.example.com
-locality widelink
