security multi-admin-verify approval-group show
PDF of this doc site
Creating your file...
Display Approval Groups
The security multi-admin-verify approval-group show
command displays information about approval groups and the users that are registered with each group.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
[-name <text>]
- Group Name-
This specifies the name of an approval group.
[-approvers <text>,…]
- Approvers-
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
[-email <mail address>,…]
- Email Addresses-
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
The following example displays typical approval groups information:
cluster1::> security multi-admin-verify approval-group show Vserver Name Approvers -------- ---------------- ----------------------------------------------------- cluster1 group1 admin group2 admin, admin1 2 entries were displayed.
