security multi-admin-verify approval-group show
Display Approval Groups
The security multi-admin-verify approval-group show command displays information about approval groups and the users that are registered with each group.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver>]- Vserver
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
- [-name <text>]- Group Name
This specifies the name of an approval group.
- [-approvers <text>,…]- Approvers
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
- [-email <mail address>,…]- Email Addresses
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
The following example displays typical approval groups information:
cluster1::> security multi-admin-verify approval-group show
    Vserver  Name             Approvers
    cluster1
             group1           admin
             group2           admin, admin1
    2 entries were displayed.
 PDFs
PDFs
