security multi-admin-verify approval-group show
Display Approval Groups
The security multi-admin-verify approval-group show command displays information about approval groups and the users that are registered with each group.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver-
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
[-name <text>]- Group Name-
This specifies the name of an approval group.
[-approvers <text>,…]- Approvers-
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
[-email <mail address>,…]- Email Addresses-
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
The following example displays typical approval groups information:
cluster1::> security multi-admin-verify approval-group show
Vserver Name Approvers
cluster1
group1 admin
group2 admin, admin1
2 entries were displayed.
