Command reference
security multi-admin-verify approval-group show
Display Approval Groups
The security multi-admin-verify approval-group show command displays information about approval groups and the users that are registered with each group.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
[-name <text>] - Group Name
This specifies the name of an approval group.
[-approvers <text>,…​] - Approvers
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
[-email <mail address>,…​] - Email Addresses
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
[-enable-notifications {true|false}] - Enable Email Notifications
This specifies whether email notifications are enabled for the approval group.
The following example displays typical approval groups information:
cluster1::> security multi-admin-verify approval-group show
Vserver Name: Cluster_Vserver
 Approval Group Name: ag
           Approvers: admin, admin1
              Emails: e1@d1.com, e2@d2.com
 Email Notifications: false
 Approval Group Name: ag1
              Emails: -
 Email Notifications: true
    2 entries were displayed.
