ONTAP 9.13.1 commands
vserver vscan scanner-pool servers add
Add to the list of hostnames
The vserver vscan scanner-pool servers add command adds one server or list of servers to the specified scanner pool.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the specified scanner pool on which you want to add a server or servers.
-scanner-pool <Scanner pool> - Scanner Pool
This parameter specifies the name of the scanner pool to which you want to add a server or servers.
-hostnames <text>,…​ - List of Host Names for Vscan Servers
This parameter specifies the host name or host names that you want to add to the specified scanner pool.
The following example adds a list of servers to the specified scanner pool.
Cluster1::> vserver vscan scanner-pool servers add -vserver vs1
            -scanner-pool SP -hostnames 2.2.2.2, vmwin204-27.fsct.nb
Cluster1::> vserver vscan scanner-pool servers show -vserver vs1 -scanner-pool SP
Vserver: vs1
                               Scanner Pool: SP
       List of IPs of Allowed Vscan Servers: 1.1.1.1, 2.2.2.2, 10.72.204.27
List of Host Names of Allowed Vscan Servers: 1.1.1.1, 2.2.2.2,
                                             vmwin204-27.fsct.nb
