system node coredump segment delete
Delete a core segment
This command deletes a core segment.
-node {<nodename>|local}
- Node-
This specifies the node on which to delete the core segments.
-segment <text>
- Core Segment-
This specifies the core segment to delete. The pathname is relative to the coredump directory. If a directory is specified, all core segment files within it are deleted. If the directory is empty, it is deleted.
[-owner-node <text>]
- Node That Owns the Core Segment File-
This specifies the node that owns the core segment. Use this parameter only in takeover mode to delete a partner's coredump segment.
This deletes all core segments in the directory, core.151708240.2012-01-11.05_56_52
cluster1::> system node coredump segment delete -node node1 -segment core.151708240.2012-01-11.05_56_52
