security login rest-role delete
Delete a REST access control role
The security login rest-role delete
command deletes a Representational State Transfer (REST) access-control role.
-vserver <vserver name>
- Vserver-
This optionally specifies the Vserver name associated with the REST role.
-role <text>
- Role Name-
This specifies the REST role that is to be deleted.
-api <text>
- API Path-
This specifies the Application Programming Interface (API) to which the REST role has access. This API can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
/api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
/api/storage/volumes/{volume.uuid}/files
/api/storage/volumes/{volume.uuid}/top-metrics/clients
/api/storage/volumes/{volume.uuid}/top-metrics/directories
/api/storage/volumes/{volume.uuid}/top-metrics/files
/api/storage/volumes/{volume.uuid}/top-metrics/users
/api/svm/svms/{svm.uuid}/top-metrics/clients
/api/svm/svms/{svm.uuid}/top-metrics/directories
/api/svm/svms/{svm.uuid}/top-metrics/files
/api/svm/svms/{svm.uuid}/top-metrics/users
In the above APIs, wildcard character
could be used in place of{volume.uuid}
or{svm.uuid}
to denoteall
volumes or_all _
SVMs, depending upon whether the REST endpoint references volumes or SVMs. -
The following command deletes a REST access-control role entry with the role name readonly
and the API /api/storage/volumes
from Vserver vs.example.com
cluster1::> security login rest-role delete -role readonly -api "/api/storage/volumes" -vserver vs.example.com cluster1::>
The following command deletes a REST access-control role entry with the role name vs1_role
and the resource-qualified endpoint corresponding to all snapshots on the volume with UUID 0aa39ec1-b68d-11ea-9581-005056bbabe6
from Vserver vs1.example.com
cluster1::> security login rest-role delete -role vs1_role -api "/api/storage/volumes/0aa39ec1-b68d-11ea-9581-005056bbabe6/snapshots" -vserver vs1.example.com cluster1::>
The following command deletes a REST access-control role entry with the role name vs2_role
and the resource-qualified endpoint corresponding to all top-metrics clients on the volume with UUID 373eb9ef-1d40-11ec-992e-005056bba268
from Vserver vs2.example.com
cluster1::> security login rest-role delete -role vs2_role -api "/api/storage/volumes/373eb9ef-1d40-11ec-992e-005056bba268/top-metrics/clients" -vserver vs2.example.com cluster1::>
The following command deletes a REST access-control role entry with the role name vs3_role
and the resource-qualified endpoint corresponding to all top-metrics directories for the Vserver vs3.example.com
with UUID 6dfeb2a7-9a16-11ec-819e-005056bb1a7c
cluster1::> security login rest-role delete -role vs3_role -api "/api/svm/svms/6dfeb2a7-9a16-11ec-819e-005056bb1a7c/top-metrics/directories" -vserver vs3.example.com cluster1::>
