security login rest-role delete
Delete a REST access control role
The security login rest-role delete command deletes a Representational State Transfer (REST) access-control role.
-vserver <Vserver Name>- Vserver-
This optionally specifies the Vserver name associated with the REST role.
-role <text>- Role Name-
This specifies the REST role that is to be deleted.
-api <text>- API Path-
This specifies the Application Programming Interface (API) to which the REST role has access. This API can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are
/api/storage/volumes/{volume.uuid}/snapshotsand/api/storage/volumes/*/snapshots..*is a wildcard character denotingallvolumes.
The following command deletes a REST access-control role entry with the role name readonly and the API /api/storage/volumes from Vserver vs.example.com .
cluster1::> security login rest-role delete -role readonly -api "/api/storage/volumes" -vserver vs.example.com cluster1::>
The following command deletes a REST access-control role entry with the role name vs1_role and the resource-qualified endpoint corresponding to all snapshots on the volume with UUID 0aa39ec1-b68d-11ea-9581-005056bbabe6 from Vserver vs1.example.com .
cluster1::> security login rest-role delete -role vs1_role -api "/api/storage/volumes/0aa39ec1-b68d-11ea-9581-005056bbabe6/snapshots" -vserver vs1.example.com cluster1::>
