security login rest-role delete
Delete an access REST control role
The security login rest-role delete command deletes an access-control role.
-vserver <Vserver Name>- Vserver-
This optionally specifies the Vserver name associated with the role.
-role <text>- Role Name-
This specifies the role that is to be deleted.
-api <text>- api path-
This specifies the api to which the role has access.
The following command deletes an access-control role with the role name readonly and the api "/api/storage/volume" for Vserver vs.example.com.
cluster1::> security login rest-role delete -role readonly -api /api/storage/volume -vserver vs.example.com
