Command reference
security login rest-role delete
Delete a REST access control role
The security login rest-role delete command deletes a Representational State Transfer (REST) access-control role.
-vserver <vserver name> - Vserver
This optionally specifies the Vserver name associated with the REST role.
-role <text> - Role Name
This specifies the REST role that is to be deleted.
-api <text> - API Path
This specifies the Application Programming Interface (API) to which the REST role has access. This API can be a private CLI API or a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
  • Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
  • File System Analytics APIs
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • ONTAP S3 APIs
  • /api/protocols/s3/services/{svm.uuid}/users
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the volume show command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes .
The following command deletes a REST access-control role entry with the role name readonly and the API /api/storage/volumes from Vserver vs.example.com .
cluster1::> security login rest-role delete -role readonly -api "/api/storage/volumes" -vserver vs.example.com
cluster1::>
The following command deletes a REST access-control role entry with the role name vs1_role and the resource-qualified endpoint corresponding to all snapshots on the volume with UUID 0aa39ec1-b68d-11ea-9581-005056bbabe6 from Vserver vs1.example.com .The volume UUID refers to the -instance-uuid field value in the volume show command output at diagnostic privilege level.
cluster1::> security login rest-role delete -role vs1_role -api "/api/storage/volumes/0aa39ec1-b68d-11ea-9581-005056bbabe6/snapshots" -vserver vs1.example.com
cluster1::>
The following command deletes a REST access-control role entry with the role name vs2_role and the resource-qualified endpoint corresponding to all top-metrics clients on the volume with UUID 373eb9ef-1d40-11ec-992e-005056bba268 from Vserver vs2.example.com . The volume UUID refers to the -instance-uuid field value in the volume show command output at diagnostic privilege level.
cluster1::> security login rest-role delete -role vs2_role -api "/api/storage/volumes/373eb9ef-1d40-11ec-992e-005056bba268/top-metrics/clients" -vserver vs2.example.com
cluster1::>
The following command deletes a REST access-control role entry with the role name vs3_role and the resource-qualified endpoint corresponding to all top-metrics directories for the Vserver vs3.example.com with UUID 6dfeb2a7-9a16-11ec-819e-005056bb1a7c .
cluster1::> security login rest-role delete -role vs3_role -api "/api/svm/svms/6dfeb2a7-9a16-11ec-819e-005056bb1a7c/top-metrics/directories" -vserver vs3.example.com
cluster1::>
The following command deletes a REST access-control role entry with the role name vs4_role and the API /api/private/cli/cluster for the Vserver vs4.example.com .
cluster1::> security login rest-role delete -role vs4_role -api "/api/private/cli/cluster" -vserver vs4.example.com
cluster1::>
