vserver nvme show-interface
Display the NVMe over Fabrics LIF configuration
The vserver nvme show-interface command displays the currently available interfaces to the NVMe protocol.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the NVMe interfaces that match the Vserver that you specify.
 [-lif <lif-name>]- Logical Interface-
Use this parameter to display the NVMe interfaces that match the LIF that you specify.
 [-vserver-uuid <UUID>]- Vserver UUID-
Use this parameter to display the NVMe interfaces that match the Vserver UUID that you specify.
 [-home-node <nodename>]- Home Node-
Use this parameter to display the NVMe interfaces that match the home node that you specify.
 [-home-port {<netport>|<ifgrp>}]- Home Port-
Use this parameter to display the NVMe interfaces that match the home port that you specify.
 [-status-admin {up|down}]- Status Admin-
Use this parameter to display the NVMe interfaces that match the administrative status that you specify.
 [-physical-protocol {fibre-channel|ethernet}]- Physical Protocol-
Use this parameter to display the NVMe interfaces that match the physical protocol that you specify.
 [-transport-protocol {fc-nvme|nvme-tcp}]- Transport Protocol-
Use this parameter to display the NVMe interfaces that match the transport protocol that you specify.
 [-transport-address <text>]- Transport Address-
Use this parameter to display the NVMe interfaces that match the transport address that you specify.
 [-comment <text>]- Comment-
Use this parameter to display the NVMe interfaces that match the textual comment that you specify.
 [-fc-wwnn <FC WWN>]- FC WWNN-
Use this parameter to display the NVMe interfaces that match the FC WWNN that you specify.
 [-fc-wwpn <FC WWN>]- FC WWPN-
Use this parameter to display the NVMe interfaces that match the FC WWPN that you specify.
 [-lif-id <integer>]- LIF ID-
Use this parameter to display the NVMe interfaces that match the LIF ID that you specify.
 [-lif-uuid <UUID>]- LIF UUID-
Use this parameter to display the NVMe interfaces that match the LIF UUID that you specify.
cluster1::*> vserver nvme show-interface
Vserver Logical Interface    Home Node:Port     Transport Protocols
vs_1
        nvme1                node1:1a           fc-nvme
          Transport Address: nn-0x2000005056b45113:pn-0x2001005056b45113
