vserver nvme show-interface
Display the NVMe over Fabrics LIF configuration
The vserver nvme show-interface command displays the currently available interfaces to the NVMe protocol.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display the NVMe interfaces that match the Vserver that you specify.
- [-lif <lif-name>]- Logical Interface
Use this parameter to display the NVMe interfaces that match the LIF that you specify.
- [-vserver-uuid <UUID>]- Vserver UUID
Use this parameter to display the NVMe interfaces that match the Vserver UUID that you specify.
- [-home-node <nodename>]- Home Node
Use this parameter to display the NVMe interfaces that match the home node that you specify.
- [-home-port {<netport>|<ifgrp>}]- Home Port
Use this parameter to display the NVMe interfaces that match the home port that you specify.
- [-status-admin {up|down}]- Status Admin
Use this parameter to display the NVMe interfaces that match the administrative status that you specify.
- [-physical-protocol {fibre-channel|ethernet}]- Physical Protocol
Use this parameter to display the NVMe interfaces that match the physical protocol that you specify.
- [-transport-protocol {fc-nvme|nvme-tcp}]- Transport Protocol
Use this parameter to display the NVMe interfaces that match the transport protocol that you specify.
- [-transport-address <text>]- Transport Address
Use this parameter to display the NVMe interfaces that match the transport address that you specify.
- [-comment <text>]- Comment
Use this parameter to display the NVMe interfaces that match the textual comment that you specify.
- [-fc-wwnn <FC WWN>]- FC WWNN
Use this parameter to display the NVMe interfaces that match the FC WWNN that you specify.
- [-fc-wwpn <FC WWN>]- FC WWPN
Use this parameter to display the NVMe interfaces that match the FC WWPN that you specify.
- [-lif-id <integer>]- LIF ID
Use this parameter to display the NVMe interfaces that match the LIF ID that you specify.
- [-lif-uuid <UUID>]- LIF UUID
Use this parameter to display the NVMe interfaces that match the LIF UUID that you specify.
cluster1::*> vserver nvme show-interface
Vserver Logical Interface    Home Node:Port     Transport Protocols
vs_1
        nvme1                node1:1a           fc-nvme
          Transport Address: nn-0x2000005056b45113:pn-0x2001005056b45113
 PDFs
PDFs
