Command reference
vserver nvme show-interface
Display the NVMe over Fabrics LIF configuration
The vserver nvme show-interface command displays the currently available interfaces to the NVMe protocol.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe interfaces that match the Vserver that you specify.
[-lif <lif-name>] - Logical Interface
Use this parameter to display the NVMe interfaces that match the LIF that you specify.
[-vserver-uuid <UUID>] - Vserver UUID
Use this parameter to display the NVMe interfaces that match the Vserver UUID that you specify.
[-home-node <nodename>] - Home Node
Use this parameter to display the NVMe interfaces that match the home node that you specify.
[-home-port {<netport>|<ifgrp>}] - Home Port
Use this parameter to display the NVMe interfaces that match the home port that you specify.
[-status-admin {up|down}] - Status Admin
Use this parameter to display the NVMe interfaces that match the administrative status that you specify.
[-physical-protocol {fibre-channel|ethernet}] - Physical Protocol
Use this parameter to display the NVMe interfaces that match the physical protocol that you specify.
[-transport-protocol {fc-nvme|nvme-tcp}] - Transport Protocol
Use this parameter to display the NVMe interfaces that match the transport protocol that you specify.
[-transport-address <text>] - Transport Address
Use this parameter to display the NVMe interfaces that match the transport address that you specify.
[-comment <text>] - Comment
Use this parameter to display the NVMe interfaces that match the textual comment that you specify.
[-fc-wwnn <FC WWN>] - FC WWNN
Use this parameter to display the NVMe interfaces that match the FC WWNN that you specify.
[-fc-wwpn <FC WWN>] - FC WWPN
Use this parameter to display the NVMe interfaces that match the FC WWPN that you specify.
[-lif-id <integer>] - LIF ID
Use this parameter to display the NVMe interfaces that match the LIF ID that you specify.
[-lif-uuid <UUID>] - LIF UUID
Use this parameter to display the NVMe interfaces that match the LIF UUID that you specify.
[-fc-topology {fabric|direct}] - FC Topology
Use this parameter to display the NVMe interfaces that match the FC topology that you specify.
cluster1::*> vserver nvme show-interface
Vserver Logical Interface    Home Node:Port     Transport Protocols FC Topology
vs_1
        nvme1                node1:1a           fc-nvme             fabric
          Transport Address: nn-0x2000005056b45113:pn-0x2001005056b45113
