ONTAP commands
storage aggregate plex delete
Delete a plex
The storage aggregate plex delete command deletes the specified plex. The aggregate specified with then -aggregate will be unmirrored and contain the remaining plex. The disks in the deleted plex become spare disks.
-aggregate <aggregate name> - Aggregate
Name of an existing aggregate which contains the plex specified with the -plex parameter.
-plex <text> - Plex
Name of a plex which belongs to the aggregate specified with the -aggregate parameter.
The following example deletes plex0 of aggregate aggr1:
cluster1::> storage aggregate plex delete -aggregate aggr1 -plex plex0
