system health policy definition modify
Modify system health policy definition
The system health policy definition modify enables or disables health monitoring policies based on input parameters the user provides.
- -node {<nodename>|local}- Node
Use this parameter to specify the node on which you want to enable or disable the policy.
- -monitor <hm_type>- Monitor
Use this parameter to specify the monitor name for which you want to be enable or disable the policy.
- -policy-id <text>- Policy
Use this parameter to specify the policy identifier that you want to enable or disable.
- [-enable {true|false}]- Policy Status
Use this parameter with the value "true" to enable the policy. Set the value to "false" to disable the policy.
- [-asup-enable {true|false}]- Enable AutoSupport for This Alert
Use this parameter to enable or disable an AutoSupport message for this alert.
This example modifies policy state on the cluster:
cluster1::> system health policy definition modify -node node1
    -policy-id ControllerToShelfIomA_Policy -enable false -monitor *
 PDFs
PDFs
