system health policy definition modify
Modify system health policy definition
The system health policy definition modify
enables or disables health monitoring policies based on input parameters the user provides.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which you want to enable or disable the policy.
-monitor <hm_type>
- Monitor-
Use this parameter to specify the monitor name for which you want to be enable or disable the policy.
-policy-id <text>
- Policy-
Use this parameter to specify the policy identifier that you want to enable or disable.
[-enable {true|false}]
- Policy Status-
Use this parameter with the value "true" to enable the policy. Set the value to "false" to disable the policy.
[-asup-enable {true|false}]
- Enable AutoSupport for This Alert-
Use this parameter to enable or disable an AutoSupport message for this alert.
This example modifies policy state on the cluster:
cluster1::> system health policy definition modify -node node1 -policy-id ControllerToShelfIomA_Policy -enable false -monitor *
