ONTAP 9.10.1 commands
system health policy definition modify
Modify system health policy definition
The system health policy definition modify enables or disables health monitoring policies based on input parameters the user provides.
-node {<nodename>|local} - Node
Use this parameter to specify the node on which you want to enable or disable the policy.
-monitor <hm_type> - Monitor
Use this parameter to specify the monitor name for which you want to be enable or disable the policy.
-policy-id <text> - Policy
Use this parameter to specify the policy identifier that you want to enable or disable.
[-enable {true|false}] - Policy Status
Use this parameter with the value "true" to enable the policy. Set the value to "false" to disable the policy.
[-asup-enable {true|false}] - Enable AutoSupport for This Alert
Use this parameter to enable or disable an AutoSupport message for this alert.
This example modifies policy state on the cluster:
cluster1::> system health policy definition modify -node node1
    -policy-id ControllerToShelfIomA_Policy -enable false -monitor *
