storage aggregate efficiency cross-volume-dedupe stop
Stops the cross volume background deduplication on an aggregate
The storage aggregate cross-volume-dedupe stop
command is used to stop cross volume background deduplication on an aggregate.
-aggregate <aggregate name>
- Aggregate (privilege: advanced)-
This specifies the aggregate on which cross volume background deduplication should be stopped. If no aggregate is specified then it will stop on all aggregates
The following example displays information for stopping cross volume background deduplication on aggregate "aggr1":
cluster:::> storage aggregate efficiency cross-volume-dedupe stop -aggregate aggr1 The efficiency operation on aggregate "aggr1" is being stopped.
