system node internal-switch show
PDF of this doc site
Creating your file...
Display onboard switch attributes
The system node internal-switch show
command is used to display the internal switch state information and the link status.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Use this parameter to specify the node the switch resides on.
[-switch-id <integer>]
- Switch-
Use this parameter to specify the switch id. For example, 1.
[-port-id <integer>]
- Port-
Use this parameter to specify the port id. For example, 0.
[-port-name <text>]
- Port Name-
Use this parameter to specify the port name. For example, e0M.
[-auto-admin <Auto-negotiation setting>]
- Auto-Negotiation Administrative-
Use this parameter to show the auto-negotiation administrative setting. 'enable' or 'disable'.
[-auto-op <Auto-negotiation setting>]
- Auto-Negotiation Operational-
Use this parameter to show the auto-negotiation operational setting. 'unknown', 'complete', 'incomplete', 'failded' or 'disabled'.
[-duplex-admin <Duplex>]
- Duplex Mode Administrative-
Use this parameter to show the duplex mode administrative setting. 'half' or 'full'.
[-duplex-op <Duplex>]
- Duplex Mode Operational-
Use this parameter to show the duplex mode operational setting. 'half' or 'full'.
[-speed-admin <Link speed>]
- Speed Administrative-
Use this parameter to show the speed administrative setting. '10', '100' or '1000'.
[-speed-op <Link speed>]
- Speed Operational-
Use this parameter to show the speed operational setting. '10', '100' or '1000'.
[-link <Link Status>]
- Link State-
Use this parameter to show the link state, 'up' or 'down'.
[-up-admin <Link Status>]
- Up Administrative-
Use this parameter to show the up administrative setting, 'up' or 'down'.
[-fc-op <Flow control>]
- Flow Control Operational-
Use this parameter to show the flow control operational setting, 'full', 'send', 'receive' or 'none'.
The example shows the attributes of the internal switch 0 on the node Node1.
cluster1::> system node internal-switch show -node Node1 -switch-id 0 Auto-Negot Duplex Speed(Mbps) Port Role Link Admin/Oper Admin/Oper Admin/Oper --- ---------------- ----- ------------------ ----------- ----------- Node: Node1 , Switch: 0 0 sw-wrench up enable/complete full/full 1000/1000 1 sw-locked-wrench down enable/incomplete full/half 100/10 2 sw-e0M up enable/complete full/full 1000/1000 3 sw-e0P down enable/incomplete full/half 100/10 4 sw-midplane-1 down enable/incomplete full/half 100/10 5 sw-expander-1 up enable/unknown full/full 100/100 6 sw-sp-1 up enable/unknown full/full 100/100 7 entries were displayed.
