statistics node show
PDF of this doc site
Creating your file...
System utilization metrics for each node in the cluster
This command continuously displays performance data for nodes at a regular interval. The command output displays data in the following columns:
Node - node name.
CPU (%) - CPU utilization.
Total Ops - total number of operations per second.
Latency(ms) - average latency for an operation in milliseconds.
[-node {<nodename>|local}]
- Node-
Selects the node for which you want to display performance data.
[-sort-key <text>]
- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>
- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer>
- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>
- Maximum Number of Instances-
Specifies the maximum number of aggregates to display. The default setting is 25.
The following example displays node statistics:
cluster1::> statistics node show cluster1 : 12/31/2013 16:00:04 CPU *Total Latency Node (%) Ops (ms) ----- --- ------ ------- node2 76 113 - node1 58 10 - [...]
