statistics node show
System utilization metrics for each node in the cluster
This command continuously displays performance data for nodes at a regular interval. The command output displays data in the following columns:
  • Node - node name.
  • CPU (%) - CPU utilization.
  • Total Ops - total number of operations per second.
  • Latency(ms) - average latency for an operation in milliseconds.
[-node {<nodename>|local}] - Node
Selects the node for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies the maximum number of aggregates to display. The default setting is 25.
The following example displays node statistics:
cluster1::> statistics node show
cluster1 : 12/31/2013 16:00:04
       CPU *Total Latency
  Node (%)    Ops    (ms)
 node2  76    113       -
 node1  58     10       -
