The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security anti-ransomware volume enable
PDF of this doc site
Creating your file...
Your file is ready
Enable anti-ransomware on a volume
The security anti-ransomware volume enable
command enables anti-ransomware monitoring on a volume.
-vserver <vserver name>
- Vserver Name-
Anti-ransomware monitoring is enabled on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>
- Volume Name-
Anti-ransomware monitoring is enabled on volumes matching the parameter value.
