security anti-ransomware volume enable
Enable anti-ransomware on a volume
The security anti-ransomware volume enable command enables anti-ransomware monitoring on a volume.
-vserver <vserver name> - Vserver Name
Anti-ransomware monitoring is enabled on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name> - Volume Name
Anti-ransomware monitoring is enabled on volumes matching the parameter value.
