vserver cifs home-directory show-user
PDF of this doc site
Creating your file...
Display the Home Directory Path for a User
The vserver cifs home-directory show-user
command prints the path of a user's CIFS home directory. Use this command if multiple CIFS home directory paths exist and you want to see which path holds the user's CIFS home directory.
[-fields <fieldname>,…]
If you specify this parameter, the command displays only the fields that you specify.
[-instance ]
If you specify the -instance parameter, the command displays detailed information about all entries.
-vserver <vserver>
- Vserver-
Use this required parameter to specify the Vserver that contains the home directory of the user specified with the required
-username
parameter. -username <text>
- User Name-
Use this required parameter to locate the home directory of the specified user. You must enter this parameter in the following format: user, domain/user or cifs_server_name/user.
[-path <text>]
- Path-
If you specify this parameter, the command displays information about the user's home directory with the specified path.
[-share-name <text>]
- Share Name-
If you specify this parameter, the command displays information about the user's home directory with the specified home-directory share.
The following command displays information about the home directory of user gpo\rpuser1 belonging to Vserver vs1.
cluster1::> vserver cifs home-directory show-user -vserver vs1 -username gpo\rpuser1 Vserver : vs1 Username : GPO/rpuser1 ShareName Home Dir Path ------------------------------------- ---------------------------------- root /home/rpuser1 rpuser1 /home/rpuser1 ~GPO~rpuser1 /home/GPO/rpuser1
The following command displays information about the home directory of user gpo\rpuser1 belonging to Vserver vs1 at share path /home/rpuser1.
cluster1::> vserver cifs home-directory show-user -vserver vs1 -username gpo\rpuser1 -path /home/rpuser1 Vserver : vs1 Username : GPO/rpuser1 ShareName Home Directory Path ------------------------------------- ---------------------------------- root /home/rpuser1 rpuser1 /home/rpuser1 2 entries were displayed.
The following command displays information about the home directory of user gpo\rpuser1 belonging to Vserver vs1 at share GPOrpuser1.
cluster1::> vserver cifs home-directory show-user -vserver vs1 -username gpo\rpuser1 -share-name ~GPO~rpuser1 Vserver : vs1 Username : GPO/rpuser1 ShareName Home Directory Path ------------------------------------- ---------------------------------- ~GPO~rpuser1 /home/GPO/rpuser1
