vserver cifs home-directory show-user
Display the Home Directory Path for a User
The vserver cifs home-directory show-user command prints the path of a user’s CIFS home directory. Use this command if multiple CIFS home directory paths exist and you want to see which path holds the user’s CIFS home directory.
{ [-fields <fieldname>,…​]
If you specify this parameter, the command displays only the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
-vserver <vserver> - Vserver
Use this required parameter to specify the Vserver that contains the home directory of the user specified with the required -username parameter.
-username <text> - User Name
Use this required parameter to locate the home directory of the specified user. You must enter this parameter in the following format: user, domain/user or cifs_server_name/user.
[-path <text>] - Path
If you specify this parameter, the command displays information about the user’s home directory with the specified path.
[-share-name <text>] - Share Name
If you specify this parameter, the command displays information about the user’s home directory with the specified home-directory share.
The following command displays information about the home directory of user gpo\rpuser1 belonging to Vserver vs1.
cluster1::> vserver cifs home-directory show-user -vserver vs1 -username gpo\rpuser1
Vserver  : vs1
    Username : GPO/rpuser1
ShareName                               Home Dir Path
    root                                    /home/rpuser1
    rpuser1                                 /home/rpuser1
    ~GPO~rpuser1                            /home/GPO/rpuser1
The following command displays information about the home directory of user gpo\rpuser1 belonging to Vserver vs1 at share path /home/rpuser1.
cluster1::> vserver cifs home-directory show-user -vserver vs1 -username gpo\rpuser1 -path /home/rpuser1
Vserver  : vs1
ShareName                               Home Directory Path
    root                                    /home/rpuser1
    2 entries were displayed.
The following command displays information about the home directory of user gpo\rpuser1 belonging to Vserver vs1 at share GPOrpuser1.
cluster1::> vserver cifs home-directory show-user -vserver vs1 -username gpo\rpuser1 -share-name  ~GPO~rpuser1
Vserver  : vs1
