volume file reservation
PDF of this doc site
Creating your file...
Get/Set the space reservation info for the named file.
The volume file reservation
command can be used to query the space reservation settings for the named file, or to modify those settings. With no further modifiers, the command will report the current setting of the space reservation flag for a file. This tells whether or not space is reserved to fill holes in the file and to overwrite existing portions of the file that are also stored in a snapshot. For symlinks, the link is followed and the command operates on the link target.
-vserver <vserver name>
- Vserver Name-
Specifies the Vserver on which the volume is located. If only one data Vserver exists, you do not need to specify this parameter.
-path </vol/<volume name>/<file path>>
- File Name-
Specifies the complete file path for which we want to get/set the space reservation settings.
[-is-enabled <text>]
- enable | disable-
Specifying enable or disable will turn the reservation setting on or off accordingly for the file.
The following example enables the file reservation setting for the file named file1. The file file1 is stored in volume testvol on Vserver vs0.
node::> file reservation -vserver vs0 /vol/testvol/file1 enable space reservations for file /vol/testvol/file1: on.
