The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network ipspace delete
PDF of this doc site
Creating your file...
Your file is ready
Delete an IPspace
Delete an IPspace that contains no ports or Vservers.
-ipspace <IPspace>
- IPspace name-
The name of the IPspace to be deleted. If the IPspace is associated with one or more logical-interfaces, you must delete them before you can delete the IPspace.
The following example deletes the IPspace "ips1".
cluster1::> network ipspace delete -ipspace ips1
