ONTAP commands
system node root-mount delete
Delete a mount from one node to another node's root volume.
The system node root-mount delete command removes a root-mount from one node in the cluster to another node's root volume. The root-mount is marked for immediate deletion by a background task. Use the system node root-mount show command to view the current status of root-mount or verify task completion.
-node <nodename> - Owner of the Root-mount
The node which has the mount.
-root-node <nodename> - Root-mount Destination Node
The node accessed by the mount.
This example shows the deletion of a root-mount from cluster1::nodeA to cluster1::nodeB and the verification of the command's successful completion.
cluster1::> system node root-mount show
Node              Root Node         State       Last Error
nodeA             NodeB                   ready
cluster1::> system node root-mount delete -node nodeA -root-node nodeB
This table is currently empty.
