network bgp peer-group rename
Rename a BGP peer group
The network bgp peer-group rename command is used to assign a new name to a BGP peer group.
-ipspace <IPspace> - IPspace Name (privilege: advanced)
This parameter specifies the IPspace of the peer group being renamed.
-peer-group <text> - Peer Group Name (privilege: advanced)
The name of the peer group to be updated.
-new-name <text> - New Name (privilege: advanced)
The new name for the peer group.
cluster1::> network bgp peer-group rename -peer-group old_name -new-name new_name
