security ipsec ca-certificate remove
Remove CA certificate(s) from a vserver
This command removes a list of IPsec CA certificates for the given Vserver. The CA certificates being removed should have been previously added to IPsec using security ipsec ca-certificate add command.
-vserver <vserver name>- Vserver Name-
Use this parameter to specify the Vserver for which the IPsec CA certificates should be removed.
-ca-certs <text>,…- CA Certificate Names-
Use this parameter to specify the list of IPsec CA certificates to be removed.
The following example removes two IPsec CA certificates named caCert1 and caCert2 for Vserver v1.
cluster-1::>security ipsec ca-certificate remove -vserver v1 -ca-certs caCert1,caCert2
