ONTAP commands
vserver cifs share access-control modify
Modify an access control list
The vserver cifs share access-control modify command modifies the permissions of a user or group in a CIFS share's ACL.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver containing the CIFS share whose ACL you want to modify.
-share <Share> - Share Name
This parameter specifies the name of the CIFS share whose ACL you want to modify.
-user-or-group <TextNoCase> - User/Group Name
This parameter specifies the user or group to modify. If you specify the user name, you must include the user's domain using the format "domain\username". The user-or-group parameter is case-insensitive text.
[-user-group-type {windows|unix-user|unix-group}] - User or Group Type
This parameter specifies the type of the user or group to modify. The default type is windows. The user-group-type can be one of the following:
  • windows
  • unix-user
  • unix-group
[-permission <access rights>] - Access Type
This parameter specifies the permissions for the user or group. The permissions can be one of the following:
  • No_access
  • Read
  • Change
  • Full_Control
The following example modifies the access control list for a share named "vol3". It changes the permission for the windows group "Everyone" to "Full_Control".
vs1::*> vserver cifs share access-control modify -share vol3 -user-or-group Everyone -user-group-type windows -permission Full_Control
The following example modifies the access control list for a share named "vol3". It changes the permission for the unix-user "pcuser" and unix-group "daemon" to "change".
vs1::> vserver cifs share access-control modify -share vol3 -user-or-group pcuser -user-group-type unix-user -permission change
        vs1::> vserver cifs share access-control modify -share vol3 -user-or-group daemon -user-group-type unix-group -permission change
