snapmirror policy show
Show SnapMirror policies
The snapmirror policy show command displays the following information about SnapMirror policies:
Vserver Name
SnapMirror Policy Name
SnapMirror Policy Type
Number of Rules in the policy
Tries
Transfer Priority
Comment for the policy
Individual Rule Names
Keep value for the Rule
Total of Keep values across all Rules in the policy
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
Selects the policies that match this parameter value.
[-policy <sm_policy>]- SnapMirror Policy Name-
[-type {vault|async-mirror|mirror-vault|strict-sync-mirror|sync-mirror|automated-failover|continuous}]- Snapmirror Policy Type-
Selects the policies that match this parameter value. A policy can be of type
async-mirror,vaultormirror-vault. [-owner {cluster-admin|vserver-admin}]- Owner of the Policy-
Selects the policies that match this parameter value. A policy can be owned by either the
"Cluster Admin"or a"Vserver Admin". [-comment <text>]- Comment-
[-tries <unsigned32_or_unlimited>]- Tries Limit-
[-transfer-priority {low|normal}]- Transfer Scheduling Priority-
[-ignore-atime {true|false}]- Ignore File Access Time-
[-restart {always|never|default}]- Restart Behavior-
[-is-network-compression-enabled {true|false}]- Is Network Compression Enabled-
[-create-snapshot {true|false}]- Create a New Snapshot Copy-
[-rpo <integer>]- Recovery Point Objective (seconds)-
[-always-replicate-snapshots {true|false}]- This prioritizes replication of app-consistent snapshots over synchronous replication-
[-snapmirror-label <text>,…]- Snapshot Copy Label-
[-keep <text>,…]- Snapshot Copy Retention Count-
[-preserve {true|false}]- Snapshot Copy Preserve Enabled-
[-warn <integer>,…]- Warning Threshold Count-
[-schedule <text>,…]- Snapshot Copy Creation Schedule-
[-prefix <text>,…]- Snapshot Copy Creation Prefix-
[-total-rules <integer>]- Total Rules in the Policy-
[-total-keep <integer>]- Total Retention Count for All Rules in the Policy-
[-common-snapshot-schedule <text>]- Common Snapshot Copy Creation Schedule for SnapMirror Synchronous (privilege: advanced)-
[-are-data-ops-sequentially-split {true|false}]- Is Sequential Splitting of Data Operations Enabled?-
[-discard-configs <network>,…]- Configurations Not Replicated During Identity Preserve Vserver DR-
[-throttle <throttleType>]- Throttle (KB/sec)-
The following example displays information about all SnapMirror policies:
cs::> snapmirror policy show
Vserver Policy Policy Number Transfer
Name Name Type Of Rules Tries Priority Comment
cs DPDefault async-mirror 2 8 normal Asynchronous SnapMirror policy for mirroring all Snapshot copies and the latest active file system.
SnapMirror Label: sm_created Keep: 1
all_source_snapshots 1
Total Keep: 2
cs MirrorAllSnapshots async-mirror 2 8 normal Asynchronous SnapMirror policy for mirroring all Snapshot copies and the latest active file system.
Total Keep: 2
cs MirrorAndVault mirror-vault 3 8 normal A unified Asynchronous SnapMirror and SnapVault policy for mirroring the latest active file system and daily and weekly Snapshot copies.
daily 7
weekly 52
Total Keep: 60
cs MirrorLatest async-mirror 1 8 normal Asynchronous SnapMirror policy for mirroring the latest active file system.
Total Keep: 1
vs0.example.com
TieredBackup vault 0 8 normal Use for tiered backups
Snapmirror-label: - Keep: -
Total Keep: 0
cs Unified7year mirror-vault 4 8 normal Unified SnapMirror policy with 7year retention.
daily 7
weekly 52
monthly 84
Total Keep: 144
cs XDPDefault vault 2 8 normal Vault policy with daily and weekly rules.
SnapMirror Label: daily Keep: 7
weekly 52
Total Keep: 59
7 entries were displayed.
The following example shows all the policies with the following fields - vserver (default), policy (default) and transfer-priority:
cs::> snapmirror policy show -fields transfer-priority
vserver policy transfer-priority
cs DPDefault normal
normal
cs MirrorAndVault
normal
cs MirrorLatest
normal
vs0.example.com
TieredBackup
normal
cs Unified7year
normal
cs XDPDefault
normal
