snapmirror policy show
Show SnapMirror policies
The snapmirror policy show command displays the following information about SnapMirror policies:
Vserver Name
SnapMirror Policy Name
SnapMirror Policy Type
Number of Rules in the policy
Tries
Transfer Priority
Comment for the policy
Individual Rule Names
Keep value for the Rule
Total of Keep values across all Rules in the policy
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
Selects the policies that match this parameter value.
 [-policy <sm_policy>]- SnapMirror Policy Name-
 [-type {vault|async-mirror|mirror-vault|strict-sync-mirror|sync-mirror|automated-failover}]- Snapmirror Policy Type-
Selects the policies that match this parameter value. A policy can be of type
async-mirror,vaultormirror-vault. [-owner {cluster-admin|vserver-admin}]- Owner of the Policy-
Selects the policies that match this parameter value. A policy can be owned by either the
"Cluster Admin"or a"Vserver Admin". [-comment <text>]- Comment-
 [-tries <unsigned32_or_unlimited>]- Tries Limit-
 [-transfer-priority {low|normal}]- Transfer Scheduling Priority-
 [-ignore-atime {true|false}]- Ignore File Access Time-
 [-restart {always|never|default}]- Restart Behavior-
 [-is-network-compression-enabled {true|false}]- Is Network Compression Enabled-
 [-create-snapshot {true|false}]- Create a New Snapshot Copy-
 [-always-replicate-snapshots {true|false}]- This prioritizes replication of app-consistent snapshots over synchronous replication-
 [-snapmirror-label <text>,…]- Snapshot Copy Label-
 [-keep <text>,…]- Snapshot Copy Retention Count-
 [-preserve {true|false}]- Snapshot Copy Preserve Enabled-
 [-warn <integer>,…]- Warning Threshold Count-
 [-schedule <text>,…]- Snapshot Copy Creation Schedule-
 [-prefix <text>,…]- Snapshot Copy Creation Prefix-
 [-total-rules <integer>]- Total Rules in the Policy-
 [-total-keep <integer>]- Total Retention Count for All Rules in the Policy-
 [-common-snapshot-schedule <text>]- Common Snapshot Copy Creation Schedule for SnapMirror Synchronous (privilege: advanced)-
 [-are-data-ops-sequentially-split {true|false}]- Is Sequential Splitting of Data Operations Enabled?-
 [-discard-configs <network>,…]- Configurations Not Replicated During Identity Preserve Vserver DR-
The following example displays information about all SnapMirror policies:
cs::> snapmirror policy show
Vserver Policy             Policy Number         Transfer
Name    Name               Type   Of Rules Tries Priority Comment
cs      DPDefault          async-mirror  2     8  normal  Asynchronous SnapMirror policy for mirroring all Snapshot copies and the latest active file system.
  SnapMirror Label: sm_created                         Keep:       1
                    all_source_snapshots                           1
                                                 Total Keep:       2
cs      MirrorAllSnapshots async-mirror  2     8  normal  Asynchronous SnapMirror policy for mirroring all Snapshot copies and the latest active file system.
                                                 Total Keep:       2
cs      MirrorAndVault     mirror-vault  3     8  normal  A unified Asynchronous SnapMirror and SnapVault policy for mirroring the latest active file system and daily and weekly Snapshot copies.
                    daily                                          7
                    weekly                                        52
                                                 Total Keep:      60
cs      MirrorLatest       async-mirror  1     8  normal  Asynchronous SnapMirror policy for mirroring the latest active file system.
                                                 Total Keep:       1
vs0.example.com
        TieredBackup       vault         0     8  normal  Use for tiered backups
  Snapmirror-label: -                                  Keep:       -
                                                 Total Keep:       0
cs  Unified7year     mirror-vault  4     8  normal  Unified SnapMirror policy with 7year retention.
                    daily                                          7
                    weekly                                        52
                    monthly                                       84
                                                 Total Keep:     144
cs      XDPDefault         vault         2     8  normal  Vault policy with daily and weekly rules.
  SnapMirror Label: daily                              Keep:       7
                    weekly                                        52
                                                 Total Keep:      59
7 entries were displayed.
The following example shows all the policies with the following fields - vserver (default), policy (default) and transfer-priority:
cs::> snapmirror policy show -fields transfer-priority
vserver     policy    transfer-priority
cs      DPDefault normal
                      normal
cs      MirrorAndVault
                      normal
cs      MirrorLatest
                      normal
vs0.example.com
      TieredBackup
                      normal
cs      Unified7year
                      normal
cs      XDPDefault
                      normal
