ONTAP commands
snapmirror policy show
Show SnapMirror policies
The snapmirror policy show command displays the following information about SnapMirror policies:
  • Vserver Name
  • SnapMirror Policy Name
  • SnapMirror Policy Type
  • Number of Rules in the policy
  • Tries
  • Transfer Priority
  • Comment for the policy
  • Individual Rule Names
  • Keep value for the Rule
  • Total of Keep values across all Rules in the policy
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
Selects the policies that match this parameter value.
[-policy <sm_policy>] - SnapMirror Policy Name
[-type {vault|async-mirror|mirror-vault|strict-sync-mirror|sync-mirror|automated-failover|automated-failover-duplex|continuous}] - Snapmirror Policy Type
Selects the policies that match this parameter value. A policy can be of type async-mirror , vault or mirror-vault .
[-owner {cluster-admin|vserver-admin}] - Owner of the Policy
Selects the policies that match this parameter value. A policy can be owned by either the "Cluster Admin" or a "Vserver Admin" .
[-comment <text>] - Comment
[-tries <integer_or_unlimited>] - Tries Limit
[-transfer-priority {low|normal}] - Transfer Scheduling Priority
[-ignore-atime {true|false}] - Ignore File Access Time
[-restart {always|never|default}] - Restart Behavior
[-is-network-compression-enabled {true|false}] - Is Network Compression Enabled
[-create-snapshot {true|false}] - Create a New Snapshot Copy
[-rpo <integer>] - Recovery Point Objective (seconds)
[-always-replicate-snapshots {true|false}] - This prioritizes replication of app-consistent snapshots over synchronous replication
[-snapmirror-label <text>,…​] - Snapshot Copy Label
[-keep <text>,…​] - Snapshot Copy Retention Count
[-preserve {true|false}] - Snapshot Copy Preserve Enabled
[-warn <integer>,…​] - Warning Threshold Count
[-schedule <text>,…​] - Snapshot Copy Creation Schedule
[-prefix <text>,…​] - Snapshot Copy Creation Prefix
[-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Snapshot Copy Retention Period
This optional parameter specifies the duration for which the snapshots associated with this rule will be locked. The parameter is specified as a number followed by a suffix. The valid suffixes are seconds , minutes , hours , days , months , and years . For example, a value of 6months represents a retention period of 6 months. It can also be set to a special value of infinite for infinite retention. The destination volume must have the snapshot-locking-enabled parameter set to true for this field to take effect else it will be ignored.
[-total-rules <integer>] - Total Rules in the Policy
[-total-keep <integer>] - Total Retention Count for All Rules in the Policy
[-common-snapshot-schedule <text>] - Common Snapshot Copy Creation Schedule for SnapMirror Synchronous (privilege: advanced)
[-are-data-ops-sequentially-split {true|false}] - Is Sequential Splitting of Data Operations Enabled? (privilege: advanced)
[-sequential-split-op-timeout-secs <integer>] - Sequential Split Op Timeout in Seconds (privilege: advanced)
[-disable-fast-resync {true|false}] - Disable Fast Resync (privilege: advanced)
[-discard-configs <network>,…​] - Configurations Not Replicated During Identity Preserve Vserver DR
[-transfer-schedule-name <text>] - Transfer Schedule Name
[-throttle <throttleType>] - Throttle (KB/sec)
The following example displays information about all SnapMirror policies:
cs::> snapmirror policy show
Vserver Policy             Policy Number         Transfer
Name    Name               Type   Of Rules Tries Priority Comment
cs      DPDefault          async-mirror  2     8  normal  Asynchronous SnapMirror policy for mirroring all snapshots and the latest active file system.
  SnapMirror Label: sm_created                         Keep:       1
                    all_source_snapshots                           1
                                                 Total Keep:       2
cs      MirrorAllSnapshots async-mirror  2     8  normal  Asynchronous SnapMirror policy for mirroring all snapshots and the latest active file system.
                                                 Total Keep:       2
cs      MirrorAndVault     mirror-vault  3     8  normal  A unified Asynchronous SnapMirror and SnapVault policy for mirroring the latest active file system and daily and weekly snapshots.
                    daily                                          7
                    weekly                                        52
                                                 Total Keep:      60
cs      MirrorLatest       async-mirror  1     8  normal  Asynchronous SnapMirror policy for mirroring the latest active file system.
                                                 Total Keep:       1
vs0.example.com
        TieredBackup       vault         0     8  normal  Use for tiered backups
  Snapmirror-label: -                                  Keep:       -
                                                 Total Keep:       0
cs  Unified7year     mirror-vault  4     8  normal  Unified SnapMirror policy with 7year retention.
                    daily                                          7
                    weekly                                        52
                    monthly                                       84
                                                 Total Keep:     144
cs      XDPDefault         vault         2     8  normal  Vault policy with daily and weekly rules.
  SnapMirror Label: daily                              Keep:       7
                    weekly                                        52
                                                 Total Keep:      59
7 entries were displayed.
The following example shows all the policies with the following fields - vserver (default), policy (default) and transfer-priority:
cs::> snapmirror policy show -fields transfer-priority
vserver     policy    transfer-priority
cs      DPDefault normal
                      normal
cs      MirrorAndVault
                      normal
cs      MirrorLatest
                      normal
vs0.example.com
      TieredBackup
                      normal
cs      Unified7year
                      normal
cs      XDPDefault
                      normal
