ONTAP 9.10.1 commands
system switch ethernet switch-count show
Display the count of cluster-network, management-network and storage-network switches.
The system switch ethernet switch-count show command displays the Ethernet switch redundancy status of the cluster that the Ethernet switch health monitor is monitoring.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed power supply information for all the switches.
[-unique-name <text>] - Cluster Unique Name
Displays the cluster name whose Ethernet switch redundancy is monitored.
[-clus-switch-count <integer>] - Ethernet Switch Count
Displays the count of cluster network switches in the cluster.
[-mgmt-switch-count <integer>] - Management Switch Count
Displays the count of management network switches in the cluster.
[-switchless-config {true|false}] - 2-Node Switchless
Displays whether the cluster is in switchless cluster configuration or not.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}] - Health Monitor
Displays the health monitor monitoring this cluster network switch redundancy information of the cluster.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Ethernet Switch Redundancy Status
Displays the Ethernet switch redundancy status of the cluster.
[-display-name <text>] - Cluster Display Name
[-stor-switch-count <integer>] - Storage Switch Count
Displays the count of storage network switches in the cluster.
cluster1::*> system switch ethernet switch-count show
Cluster   Management Storage  Switchless
Sw Count  Sw Count   Sw Count Config
2         1          2        false
Shows the count of Ethernet switches (including cluster, management and storage networks) and the switchless configuration status of the cluster.
