system switch ethernet switch-count show
Display the count of cluster-network, management-network and storage-network switches.
The system switch ethernet switch-count show
command displays the Ethernet switch redundancy status of the cluster that the Ethernet switch health monitor is monitoring.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays the fields that you specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed power supply information for all the switches. [-unique-name <text>]
- Cluster Unique Name-
Displays the cluster name whose Ethernet switch redundancy is monitored.
[-clus-switch-count <integer>]
- Ethernet Switch Count-
Displays the count of cluster network switches in the cluster.
[-mgmt-switch-count <integer>]
- Management Switch Count-
Displays the count of management network switches in the cluster.
[-switchless-config {true|false}]
- 2-Node Switchless-
Displays whether the cluster is in switchless cluster configuration or not.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}]
- Health Monitor-
Displays the health monitor monitoring this cluster network switch redundancy information of the cluster.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Ethernet Switch Redundancy Status-
Displays the Ethernet switch redundancy status of the cluster.
[-display-name <text>]
- Cluster Display Name-
[-stor-switch-count <integer>]
- Storage Switch Count-
Displays the count of storage network switches in the cluster.
cluster1::*> system switch ethernet switch-count show Cluster Management Storage Switchless Sw Count Sw Count Sw Count Config --------- ---------- -------- ---------- 2 1 2 false
Shows the count of Ethernet switches (including cluster, management and storage networks) and the switchless configuration status of the cluster.
