      vserver nfs delete
Delete the NFS configuration of a Vserver
The vserver nfs delete command deletes the NFS configuration of a specified Vserver. This command does not delete the Vserver itself, just its ability to serve NFS clients.
If you delete a Vserver, the Vserver's NFS configuration is automatically deleted. Any Windows-to-UNIX or UNIX-to-Windows name mappings defined for the Vserver are also deleted because they require both the CIFS and NFS servers. |
-vserver <vserver name>- Vserver-
This specifies the Vserver whose NFS configuration you want to delete.
The following example deletes the NFS configuration of a Vserver named vs2:
cluster1::> vserver nfs delete -vserver vs2
