security ipsec ca-certificate show
Displays the CA certificates added to IPsec
This command displays the configured IPsec CA certificates.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If you specify this parameter, then the command displays only the IPsec CA certificates configured for the given vserver.
[-ca-certs <text>,…]- CA Certificate Names-
If you specify this parameter, then the command displays only the Vservers configured with the IPsec CA certificates with the given names.
The following example lists the IPsec CA certificates configured for all Vservers.
cluster-1::>security ipsec ca-certificate show Vserver CA Certificate Names ------------------ ---------------------------------- v1 caCert1, caCert2 v2 caCert3, caCert4 2 entries were displayed.
