network port reachability scan
Perform a reachability scan
Scan network port configuration to detect reachable broadcast domains.
-node {<nodename>|local}
- Node-
Selects the node on which the port resides.
-port <netport>
- Port-
Selects the port on which to scan broadcast domain reachability.
The following example applies the scanned broadcast domain reachability information to the specified port’s configuration.
cluster1::> network port reachability scan -node node1 -port e0c
