      network port reachability scan
Perform a reachability scan
Scan network port configuration to detect reachable broadcast domains.
- -node {<nodename>|local}- Node
Selects the node on which the port resides.
- -port <netport>- Port
Selects the port on which to scan broadcast domain reachability.
The following example applies the scanned broadcast domain reachability information to the specified port's configuration.
cluster1::> network port reachability scan -node node1 -port e0c
 PDFs
PDFs
