The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port reachability scan
PDF of this doc site
Creating your file...
Your file is ready
Perform a reachability scan
Scan network port configuration to detect reachable broadcast domains.
-node {<nodename>|local}
- Node-
Selects the node on which the port resides.
-port <netport>
- Port-
Selects the port on which to scan broadcast domain reachability.
The following example applies the scanned broadcast domain reachability information to the specified port's configuration.
cluster1::> network port reachability scan -node node1 -port e0c
