ONTAP commands
network options cluster-health-notifications modify
cluster health notification options
This command enables or disables cluster health notifications on the specified node.
-node {<nodename>|local} - Node
This parameter specifies the node for which the cluster health notification status will be modified.
[-enabled {true|false}] - Cluster Health Notifications Enabled
Setting this parameter to true enables cluster health notification. Setting it to false disables cluster health notification.
The following example modifies the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications modify -node node1 -enabled true
Looking for answers?
Try Doc, our Gen AI Assistant.
