      network options cluster-health-notifications modify
cluster health notification options
This command enables or disables cluster health notifications on the specified node.
-node {<nodename>|local}- Node-
This parameter specifies the node for which the cluster health notification status will be modified.
 [-enabled {true|false}]- Cluster Health Notifications Enabled-
Setting this parameter to
trueenables cluster health notification. Setting it tofalsedisables cluster health notification.
The following example modifies the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications modify -node node1 -enabled true
