network options cluster-health-notifications modify
cluster health notification options
This command enables or disables cluster health notifications on the specified node.
-node {<nodename>|local}
- Node-
This parameter specifies the node for which the cluster health notification status will be modified.
[-enabled {true|false}]
- Cluster Health Notifications Enabled-
Setting this parameter to
true
enables cluster health notification. Setting it tofalse
disables cluster health notification.
The following example modifies the cluster health notification status for a node:
cluster1::> network options cluster-health-notifications modify -node node1 -enabled true
