security anti-ransomware volume dry-run
Dry-run anti-ransomware on a volume
The security anti-ransomware volume dry-run command starts anti-ransomware monitoring in the evaluation mode on a volume.
-vserver <vserver name> - Vserver Name
Anti-ransomware monitoring is enabled in the evaluation mode on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name> - Volume Name
Anti-ransomware monitoring is enabled in the evaluation mode on volumes matching the parameter value.
