security anti-ransomware volume dry-run
Dry-run anti-ransomware on a volume
The security anti-ransomware volume dry-run
command starts anti-ransomware monitoring in the evaluation mode on a volume.
-vserver <vserver name>
- Vserver Name-
Anti-ransomware monitoring is enabled in the evaluation mode on volumes that match the values for the Vserver and volume parameters. If only one data Vserver exists, you do not need to specify this parameter.
-volume <volume name>
- Volume Name-
Anti-ransomware monitoring is enabled in the evaluation mode on volumes matching the parameter value.
